Enables or disables fast-reroute protection for the specified LSP.
| lsp_name | Specifies the name of the LSP you are configuring. |
Disabled.
To signal the fast-reroute protected LSP, use the enable mpls rsvp-te lsp [lsp_name | all] command. Similarly, to disable the fast-reroute protected LSP, use the disable mpls rsvp-te lsp [lsp_name | all] command.
This command enables fast-reroute protection on LSP aus:
configure mpls rsvp-te lsp aus fast-reroute enable
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
